The Cisco 300 series, part of the Cisco Small Business line of network solutions is a portfolio of affordable managed switch that provides a reliable foundation for your business network. This switch delivers the features you need to improve the availability of your critical business applications, protect your sensitive information, and optimize your network bandwidth to deliver information and applications more effectively. Easy to set up and use, the Cisco 300 series provides the ideal combination of affordability and capabilities for small businesses, and helps you create a more efficient, better-connected workforce.
The Cisco 300 series is broad portfolio of fixed-configuration managed Ethernet switch. However, unlike other small business switching solutions that provide managed network capabilities only in the costliest models, all Cisco 300 series switch supports the advanced security management capabilities and network features you need to support business-class data, voice, security, and wireless technologies. At the same time, this switch is simple to deploy and configure, allowing you to take advantage of the managed network services your business needs.
