Designed for hot-plug and redundant setups, this power supply ensures your network hardware remains operational, minimizing downtime and maintaining productivity.
Versatile compatibility
With its plug-in module form factor, this power supply offers seamless compatibility with a wide range of network hardware, providing a flexible solution for your power needs.
Cisco Config 1 Secondary Power Supply - power supply - hot-plug / redundant - 715 Watt
Power supply - hot-plug / redundant - plug-in module
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Input Connectors
Power IEC 60320 C16
Output Voltage
-56 V
Power Capacity
715 Watt
MTBF
664,055 hours
CISPR 22 Class A, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, EN50082-1, EN 61000-6-1, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, AS/NZ 3548 Class A, CCC, ICES-003 Class A, EN 61000-4-5, UL 60950-1, IEC 60950-1, EN 60950-1, FCC Part 15 A, CSA C22.2 No. 60950-1, BSMI Class A, VCCI Class A, EN 300 386
