For high quality output the i-SENSYS LBP7660Cdn has 9600 x 600 dpi print resolution that's enhanced with automatic image refinement for a perfect finish on every print. The printer comes with 768 MB of memory as standard, giving it the capacity to cope with large, complex documents and graphics, as well as the demands of network printing.
The i-SENSYS LBP7660Cdn integrates seamlessly into your business operations through its support for the industry-standard PCL5c/6. With built-in Gigabit Ethernet connection, it can also handle demanding workloads to ensure optimum network performance.
The superior energy efficiency of the i-SENSYS LBP7660Cdn means you can cut costs - as well as your impact on the environment. ENERGY STAR compliant, it consumes only 1.0 watts of power in sleep mode and has a low Typical Energy Consumption (TEC) figure, to make it one of the most efficient in its class. With automatic double-sided printing built-in you can reduce paper usage, not only saving money but also being more considerate to the environment.
