The HD-SMX404 is a compact unit which allows you to connect the output from four High Definition sources and display them up to four HDMI display devices. For example, a set top box, DVD player and game console can be connected to four HDMI equipped displays. You can choose to duplicate outputs or have different sources on each display.
The HDMI matrix can be used as a switch, a splitter or a combination of both giving you total flexibility.
