Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250 MHz.
- 2 Mtr
- Blue
- UTP (Unshielded Twisted Pair)
- CAT 6
- Moulded
- 24AWG x 4P
- Patch Type CM (UL) CMH E164469-F3
- ISO/IEC 11801 & EN 50288 & TIA/EIA-563-B.2-1 ETL/3P VERIFIED
