Cost-effective solution that provides higher bandwidth and transmission
rates and supports longer distances with lower loss than 62.5/125 fibre.
Specifically designed for use with today's narrower aperture components,
this cable is fully compatible with multimode applications.
The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials
that lessen the smoke and halogen emissions when the cable is exposed to
extreme temperatures.
This reduces the amount of harmful toxic and corrosive gases that cabling
made with plastic materials would otherwise emit into the air during
combustion. This construction makes LSZH cables ideal for use where the
protection of people and equipment from harmful corrosive gases is
absolutely critical.
The patented injection moulding process provides each connection greater
durability in resisting pulls, strains and impacts from cabling installs.
Each cable is 100% optically inspected and tested for insertion loss before
you receive it. A pull-proof jacket design surrounds the popular 50/125
multimode fibre, immune to electrical interference.
Connector 1: (1) ST Male
Connector 2: (1) ST Male
