SuperSpeed USB 3.0 hard disk drive
DriveStation™ Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 RPM drive. With USB 3.0, digital content transfers at speeds of up to 5Gbps*. If you haven't moved up to USB 3.0 yet - DriveStation™ Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Features and Benefits
- SuperSpeed USB 3.0: The USB 3.0 interface moves data at rates of up to 5 gigabytes per second*, ideal for video and other dataintensive digital content
- TurboPC EX utility: TurboPC EX adds more performance to Buffalo's TurboPC with TurboCopy performance and copy enhancement utility for Windows. Now saving, copying, and transferring files is even faster.
- High speed 7,200 RPM hard disk: The disk reads and writes data faster, so you spend less time waiting when transferring and saving files
- Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access on Windows PCs
- Back Up Your Files: Buffalo's Backup Utility automatically backs up your Windows PC, protecting your data
- RAMDISK virtual disk utility: The Windows RAMDISK utility creates a small "virtual hard disk" using your computer's RAM (random access memory)
- eco Manager: Eco minded power management tool for Windows regulates power usage, conserving energy and battery consumption
- SuperEco: saves power consumption during stand-by mode by Auto Power OFF
- SecureLock Manager: Easy software simplifies access for you while keeping others out on Windows PCs
- Plug & Play Connectivity: Connecting and using the drive is simple-just plug it in to any USB port on a computer or other device you're connecting to. No need to install any drivers and no confusing settings.
- Fully backwards compatible with USB 2.0: No adjustments are needed, just plug into any USB 2.0 port
- 2-Year Warranty
