 | Caller DisplayIf you have subscribed to a Caller Display Service, you will be able to see your caller’s number on your handset display (provided it is not withheld) prior to answering the call. If your caller’s name is stored in the directory and a number match is found, you will see the caller’s name on the display instead. |
