| Type: | Fax / copier / printer / scanner |
| Functionality: | Copier, Fax, Scanner, Printer |
| Max Paper Size: | A4 (210 x 297 mm), Legal (216 x 356 mm) |
| Quicklinx: | CTP4WS00 |
| Mfr#: | MFCL8690CDWZU1 |
MFC-L8690CDW
High-resolution colour laser all-inone printer with outstanding print speeds of up to 31ppm and 2-sided scan speeds of up to 56ipm in both colour and mono. You can be confident that efficiency has been at the heart of the design.
Key Features
Increase productivity levels
Meeting security challenges
Modern businesses demand the highest levels of security. With Secure Function Lock 3.0 Active Directory Authentication Internet Protocol Security (IPsec) 802.1x and Secure Print you can be confident that your documents are safe
Flexible and low running costs
Designed for high volume printing environments the MFC-L8690CDW includes a 3000 page black and 1800 page cyan magenta and yellow toners and can take optional 6500 page black and 4000 page cyan magenta and yellow toners to lower your running costs even further.
