Brother HL-3140CW Compact Colour Laser Printer With Wi-fi
At last, a compact, high quality colour printer that is affordable to buy and affordable to run too. This is an exciting development for many small to medium sized businesses who want the impact of using colour.
This entry level printer is part of Brother's next generation colour LED printers, designed for high performance and better value. It's fast, printing 18 pages per minute, easy to use, and built for reliability, giving you the peace of mind that it won't let you down. It offers advanced and flexible connections, whether you need to print direct from USB, or web-based applications such as Apple AirPrint or Google Cloud Print.
- Save time with fast 18ppm mono/colour printing
- Flexible paper handling with 250 sheet paper capacity and single sheet bypass tray
- Faster and more secure 802.11n wireless connection or connect to your PC via high speed USB 2.0
- Effortless mobile connectivity enables printing direct from your Apple iOS, Android, Windows Phone or Blackberry device
- Lower operational costs with optional high yield colour supplies
- Print professional colour documents with output of up to 2,400 x 600dpi resolution
Compact, reliable and specially designed to suit the smaller office space. Create professional-looking colour documents and print directly from your mobile device for the ultimate convenience. Plus wireless technology means saving and sharing resources is easy.
Key Features
- Print only
- Up to 18ppm mono and colour print speed
- Up to 2,400 x 600dpi print resolution
- Wireless network ready
- Print from your mobile device
- PIN and password protected secure print
- Compact, reliable and specially designed to suit smaller office spaces
- Create professional-looking colour documents and print directly from your mobile device to the HL-3140CW for the ultimate convenience. Plus wireless technology means saving and sharing resources is easy.
- Like all of our colour LED printers, it incorporates separate toners and drums, reducing waste and saving you money. This flexible printer also offers high-yield colour toner cartridges to keep costs down without compromising on quality.
- And with print speeds of up to 18ppm, the HL-3140CW won't keep you waiting for your documents.
AirPrint
Compatible with AirPrint by Apple.
Mobile Compatible
Mobile device compatible. Connect with your smartphone or tablet.
WiFi Compatible
Wireless compatible.
