XL features the premiere monitors for PC e-Sports, fine-tuned to deliver the smooth and responsive experience, and the clear images to arm you for competition.
Catch every detail of motion and enjoy the fluid gameplay by BenQ Zowie native 240 Hz refresh rate monitor, which ensures a flawless view of fast motion consistently at all time.
Shield - help you focus on the game
Shield - reveal the way to be concentrated in games. The adjustable angle and removable design allows Shield to adopt various environments, according to preference. Just focus on winning the game.
Spot hidden enemies
Never fall victim to some cowardly camper in a dark corner again. Black eQualizer increases the visibility in dark scenes without overexposing the bright areas.
Optimize gaming precision
Color Vibrance gives you the flexibility to get the color performance. With 20 levels of Color Vibrance settings, you can get specific viewing requirements and preferences for all types of gameplay.
Personalize viewing angles
The height adjustable stand can be operated with just one finger, so you can easily adjust the height of the monitor to your preferred viewing angle, maximizing your comfort.
BenQ ZOWIE XL2540 - XL Series - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class B
Energy Consumption per Year
49 kWh
Power Consumption (On mode)
33 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Voltage
AC 90 - 264 V (47 - 63 Hz)
Black, red
51.543 cm x 22.604 cm x 56.994 cm
7.5 kg
Display Type
Energy Class
Class B
49 kWh
Diagonal Size
24.5"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
24 - 240 Hz
Horizontal Refresh Rate
15 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Black eQualizer, Low Blue Light Mode, Flicker Free technology, Shield
Black, red
51.543 cm x 22.604 cm x 56.994 cm - with stand
7.5 kg
2 x HDMI , DisplayPort , DVI-D (dual link) , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones , Microphone
