Featuring 16:10 widescreen aspect ratio, 100% sRGB, flicker-free technology, Senseye reading mode and eye protect sensor, the BL2411PT is tailor made is tailor made to meet the exceptional screen performance and superb user experience.
Designed for business environments, the BenQ BL2411PT of professional monitors is an essential part of your solutions to minimize total cost of ownership and maximize staff productivity - a win-win decision for the benefits of all.
Visual performance
For viewing videos from HD camcorders or photos on digital cameras, the monitor reproduces 100% sRGB color to deliver authentic, natural visuals that match the color details of the original source perfectly.
16:10 wide aspect ratio
16:10 widescreen aspect ratio offers 1920 x 1200 maximum resolution and the ease of viewing documents and working in multiple windows with minimized scrolling and toggling between applications.
Ultra-flexible Height Adjustment System (HAS)
An extensive range of monitor adjustments - height, tilt, pivot, stroke and swivel - tailors to your unique build and viewing habits perfectly.
Automatic eye-protect sensor
Ambient light levels are automatically detected to help adjust the monitor brightness throughout the day for optimized clarity and viewing comfort.
Anti-glare display
A glare panel - whether it's caused by a direct or reflected light source - makes it a challenge for office workers to see clearly without straining their eyes. The BenQ BL2411PT monitors feature an anti-glare, matt-finish display to keep distracting reflections to a minimum, so office workers can work through their day-to-day tasks with well-improved efficiency - squint-free!
Eco sensor
To help reduce energy waste and CO2 emissions, the eco sensor feature automatically switches the monitor to eco mode when you step away from your computer. This also helps lower your electricity costs effectively.
BenQ BL2411PT - BL Series - LED monitor - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
AC 90 - 264 V
44.4 cm x 23.6 cm x 55.5 cm
6.7 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, EN 60950, TUV Ergo, ISO 9241-307
3-year warranty
Display Type
Diagonal Size
24"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, H/V position, sharpness, colour balance, input select, colour temperature
