"Oh come on, you can make it" you say, while the taut monitor cable stretches, as you try to plug it into your computer. Suddenly, your new monitor flies off the desk and into pieces. You should have used a Belkin Pro Series Monitor Extension Cable, and saved your monitor and yourself. Pro Series VGA Monitor Extension Cable extends the length of an existing Super VGA monitor cable with high-density DB15 connectors.
PRODUCT FEATURES:
State-of-the-art wiring design ensures 100% compatibility with all devices 100% of the time;
Flextec cable jacket is very durable and extremely flexible for use in tight areas;
Oversized ergonomic thumbscrews make installation a breeze;
24K gold plated copper contacts provide maximum conductivity with no data loss;
Ground indents provide excellent conductivity and retention with mating conductors;
PVC premold encapsulates individual conductors to ensure electrical isolation and relieve stress;
Aluminum undermold shield helps to meet FCC requirements on EMI/RFI interference;
28 AWG stranded tinned copper conductors are individually insulated in polypropylene to minimize cross talk, ensuring high-speed, error-free transmission;
