Easily access the Web
Designed for easy setup, the Belkin N150 Wireless Router lets you get your wireless network up and running in three steps. Belkin's exclusive MultiBeam technology minimizes dead spots and provides strong coverage throughout your home, and preset security settings ensure that your network is safe. With twice the speed of G technology, the N150 is ideal for wirelessly surfing the Web, emailing, and instant messaging.
MultiBeam Technology
Belkin's exclusive MultiBeam antenna technology gives you powerful signal strength and maximum coverage, while minimizing dead spots--so you can connect from virtually anywhere in your home.
Speed
The N150 provides wireless speeds of up to 150Mbps*--ideal for surfing, emailing and instant messaging.
Fully Compatible with G Technology
Wireless-N technology offers twice the speed of G technology† yet is fully compatible with older wireless-G networks, as well as newer 802.11n networks.
Easy Setup
Get your secure wireless network up and running in minutes. Just three easy steps, and you're you out of the box and onto the Web.
Preset Security
WPS/WPA2 encryption standards and preset security settings get you up and running safely. One-touch Wi-Fi Protected Setup (WPS) securely connects multiple computers and devices with the push of a button.
*The standard transmission rates--150Mbps, 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower.
†Twice the speed and other physical data rates are achievable only when used in combination with an N150 Wireless USB Adapter.
