Charge and sync your Micro-USB devices as well as Lightning connector devices using just one cable. Simply plug the USB end directly into any USB port to charge and sync rapidly and safely.
Use the 3-foot Micro-USB to USB Cable to charge and sync your Samsung Galaxy S 4, Galaxy S III, Galaxy S II, or Galaxy Note II Smartphone at the fastest possible speed. The small, durable Micro-USB connector also works with most smartphones and tablets with a Micro-USB port, including Samsung, Kindle, HTC, Nokia, LG, Nexus and Motorola. Use the Lightning connector to adapter to charge your iPhone 5, iPod touch (5th generation) iPad with Retina Display (4th generation), or iPad mini at the fastest possible speed. The smaller, more durable Lightning connector is also reversible, which makes plugging it in easier than ever.
Use it anywhere
The Micro-USB to USB cable plugs into any USB 2.0 port, so you can use it virtually anywhere. Connect to your laptop to charge and sync, use your own wall charger to charge from the wall, or plug into a car charger and charge on the road.
Case compatibility
Depending on the type of case you have, you may need to remove your case before charging. If your speakers, connector port and AUX port are fully exposed when your case is on, you should be able to easily charge and sync your device without removing the case.
Belkin cable kit - 91.4 cm
Cable
Cable kit
Length
91.4 cm
Sync and charge
Cable Type
Cable kit
Length
91.4 cm
Sync and charge
Details
Included Qty x Type
Charging / data adapter - Lightning (male) to 5 pin Micro-USB Type B (female) , USB cable - 5 pin Micro-USB Type B (male) to 4 PIN USB Type A (male), 91.4 cm
