Use a single connection from your router to pass Internet by HDMI cable to all your HEC capable devices.
Audio return channel
Allows for onboard TV tuners to stream audio to your A/V receiver through a single HDMI cable.
Picture perfect quality
It is supporting pass through of all video resolutions between 480i and 1080p as well as 640 x 480 up to 1920 x 1200 for the high quality of video capable from sources.
Atlona AT-HD4-V41 - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
Ports
4 x HDMI
Performance
Bandwidth: 6.75 Gbps
HDCP compliant, Audio Return Channel (ARC), HDMI Ethernet Channel (HEC), 3D support
24 cm x 11 cm x 5 cm
810 g
3-year warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Performance
Max Resolution
1920 x 1200 / 1080p
Status Indicators
Power, status
4 x HDMI input , 1 x HDMI output , 1 x serial (RS-232) DB-9 management , 1 x SPDIF output RCA , Remote control: 1 x IR - mini-phone stereo 3.5 mm , 1 x 10Base-T/100Base-TX - RJ-45
