ASUS brings you the world's first discrete USB 3.1 card. ASUS USB 3.1 card is the simple-to-fit PCI Express expansion card that works with any PCIe slot. It adds dual USB 3.1 ports to your ASUS motherboard for ultimate-speed transfers of up to 10 Gb/s - or twice as fast USB 3.0. The next-generation standard is completely backward-compatible with your existing gear, and you'll be all set for USB 3.1's breakneck speeds. And ASUS-exclusive USB 3.1 boost technology pushes real-world speeds faster than ever before.
