Dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images.
Full HD with HDMI
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port.
178° wide viewing angle
PB238Q adopts 178° of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it.
Extensive connectivity and built-in stereo speaker for multimedia enjoyment
PB238Q comes with rich connectivity including HDMI, DisplayPort, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc Simultaneously connect to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with built-in stereo speakers.
QuickFit virtual scale
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Volume, brightness, contrast, input select, colour temperature
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
54.88 cm x 20.1 cm x 41.42 cm - with stand
5.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , DVI-D , Audio line-in , DisplayPort , HDMI , 4 x USB 2.0 downstream , USB 2.0 upstream (Type B)
Mechanical
Display Position Adjustments
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x USB cable - USB Type A to B
Compatible with Windows 7
