Open your eyes to breathtaking levels of detail with the ASUS PA328Q true 4K ultra-high definition monitor. It features a super-narrow bezel design and a 16:9 aspect, 32-inch panel to give you stunning visuals in resolutions of up to 3840 x 2160. PA328Q gives you 300% more onscreen space to work with than similarly-sized Full HD displays, allowing you to spread out your various work windows for more productive multitasking. Revel in pure, expressive hues thanks to accurate, true-to-life color reproduction. Each PA328Q monitor is factory pre-calibrated to guarantee industry-leading color accuracy, so your images are accurately reproduced onscreen, allowing you to see exactly how your work is going to look when it's finished. Increase productivity and work smarter with ASUS QuickFit Virtual Scale. PA328Q provides you with an onscreen grid overlay so you can align and preview photos and documents in their actual sizes prior to printing. There's also an intuitive 5-way navigation joystick so you can easily access and switch OSD settings on the onscreen menu. When you're spending countless hours working on a project, it's important to have a display with low blue light technology to reduce instances of strained eyes. Say goodbye to tired eyes with ASUS Eye Care technology.
