PA238Q adopts 178 of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it.
Versatile comfort with ergonomic design
The ergonomically-designed PA238Q professional monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
Hassle-free connection
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
Mercury-free LED-backlit panel
Embedded LED backlight panel helps power saving and environmental protection with no mercury usage.
Human sensor integrated for power saving
An integrated human sensor detects the user's presence or absence in front of the monitor. When the user leaves the desk, PA238QR will automatically switch to power saving mode and turn on the monitor once he or she is back, to help reduce energy consumption with inactivity.
ASUS PA238QR - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Presence sensor, USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
5.5 kg
Microsoft Certification
Compatible with Windows 7
3-year warranty
Display Type
Energy Class
Class B
38 kWh
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2652 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, gamma correction, input select, colour temperature
Picture in picture, picture by picture, HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, Color Rich Technology
- with stand
5.5 kg
VGA (HD-15) , HDMI , DVI-D , DisplayPort , USB 2.0 upstream , 4 x USB 2.0 downstream , Headphones
1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable
