Winning gamers need winning accessories and Cerberus is designed to help you secure victory in every scenario - and it's also a great headset for everyday listening! Connect Cerberus to your desktop, laptop or smart device to experience superb sound with brilliant detail and punchy bass no matter what you do or where you do it.
If you've not felt the power of 60 mm neodymium-magnet drivers then listen with Cerberus - you'll experience unrivaled punch and audio immersion that's utterly convincing. When gaming you'll hear every gunshot and know enemies are nearby from their footsteps alone. Then, switch to audio for roomy stadium rock, crisp and clear spoken-word listening or movie soundtracks that sound so real.
Cerberus has full-size 100 mm polyurethane-coated leather ear cushions for great durability and effective noise isolation, so you can enjoy audio without being disturbed by the outside world. And Cerberus is designed with comfort that lasts: the highly-breathable cushions and the headband's finely-balanced clamping forces mean you can listen for much longer.
