A case as beautifully designed as iPad itself, the iPad Pro Leather Sleeve is made from top-quality leather. It protects your iPad with a soft microfiber lining and stores your Apple Pencil so you always have it with you.
Apple - protective sleeve for tablet
Protective sleeve for tablet
Screen Size Compatibility
12.9"
Material
Leather
Saddle brown
12.9-inch iPad Pro (1st generation, 2nd generation)
Material
Leather
Lining Material
Microfibre
Saddle brown
Carrying Case
Protective sleeve
Recommended Use
For tablet
12.9"
Additional Compartments
Apple Pencil
Apple 12.9-inch iPad Pro (1st generation, 2nd generation)
