            Whether you're enjoying photos, shopping, or building a presentation, the vivid 9.7-inch Retina display has the detail and size to really bring them to life. The 64-bit A9 chip delivers performance that makes every app feel fast and fluid. Explore rich learning apps, play graphics-intensive games, or even use two apps at once. All while enjoying up to 10 hours of battery life. Taking photos and videos with iPad is a snap. Use the 8-megapixel camera to shoot detailed images or 1080p HD video and then edit them right on iPad with Photos, iMovie, or your favorite app from the App Store. Or use the front-facing FaceTime HD camera for video calls and gorgeous selfies. At just one pound and 7.5 mm thin, iPad is designed to go wherever you go. And it's as durable as it is portable, with an aluminum unibody construction that delivers a reassuringly solid feel.
iPad is designed to stay connected wherever you go. Fast 802.11ac Wi-Fi delivers up to 866-Mbps throughput. The Wi-Fi + Cellular model supports LTE networks worldwide for convenient connectivity.
