RYZEN POWERS. YOU FIGHT.
EXPERIENCE PREY® ON THE NEW AMD RYZEN™ 5 PROCESSORS.
AMD Ryzen™ 5 1400
Performance Gaming and Processing - 4 processor cores with 8 threads with true machine intelligence
- 3.2 GHz clock rate with 3.4 GHz Precision Boost
- AMD Wraith Stealth cooler
- 65 Watt TDP
AMD Ryzen Master Utility
Every AMD Ryzen processor is multiplier-unlocked from the factory, so you can personalize performance to your taste. AMD provides the AMD Ryzen Master utility to access this powerful advantage
Personalized Performance
AMD Ryzen Master provides for up to four profiles to store custom clocks and voltage adjustments for both the Ryzen™ CPU and DDR4 memory. You can park cores and adjust memory timings, too.
System Monitoring
Accurate hardware status updates are vital, so AMD Ryzen Master has you covered with both real-time monitoring and a histogram of per-core clock rates and temperature, including average and peak readings.
AMD SenseMI Technology
AMD introduces SenseMI technology, a set of learning and adapting features that help the AMD Ryzen™ processor customize its performance to you and your applications. Finally: performance that thinks.
Pure Power
Cool and quiet processor operation using a sophisticated grid of smart sensors.
- Monitors CPU temperature, resource usage, and power draw
- Adaptive control optimizes power draw for any workload
- Minimized power consumption reduces system heat and noise
Precision Boost
Fine-tuned processor performance adjusted in real time to meet the performance demands of your game or app.
- Adjusts clockspeeds in 25MHz increments to optimize performance
- Clockspeed changes can occur without pausing work
- High precision tuning with 25MHz increments
Extended Frequency Range
Automatic extra performance boost for enthusiasts with premium systems and processor cooling.
- Permits CPU speeds above and beyond ordinary Precision Boost limits
- Clockspeed scales with cooling solution: air, water, and LN2
- Fully automated; no user input required
- Available on select AMD Ryzen processors
Neural Net Prediction
Built-in artificial intelligence that primes your processor to tackle your app workload more efficiently.
- A true neural network inside every AMD Ryzen processor
- Builds a temporary map of how your programs use the CPU
- Prepares the fastest processor pathways for your app’s behaviors
Smart Prefetch
Learning algorithms that predict and pre-load needed data for fast and responsive computing.
- Learns how your applications access their own data
- Sophisticated algorithms anticipate and pre-load that data into the AMD Ryzen processor
- Vital data is ready when you are, enabling peak performance
"Zen" Core Architecture
Maximum Compute Efficiency
The "Zen" core is an all-new "clean sheet" x86 processor design that’s inspiring a new generation of high-performance AMD computing products in 2017 and beyond. "Zen" combines the latest thinking in high-throughput and low-power design methodologies to create a balanced and versatile architecture right at home in the desktop, laptop, datacenter and supercomputer.
Performance and Efficiency for Next-?Gen Applications
Cloud computing, enterprise productivity, immersive visual experiences, gaming and data security open up new frontiers – and demand more computing performance with maximum energy efficiency. From the very beginning, AMD engineers designed the new "Zen" core to meet those demands with a high-performance execution engine, large caches, and powerful multi-threading capabilities.
"Zen" Microarchitecture Details
"Zen" cores are designed to efficiently use available microarchitectural resources for optimal compute performance. Compared to our previous architecture, three-tier cache system and new pre-fetch algorithms enable dramatically higher throughput in the cache and execution engines.
Powered by the AM4 Platform
The new AMD AM4 Platform puts effortless compatibility front and center. Our new 1331-pin processor socket works with the 7th Gen AMD APU, AMD Ryzen CPU, and the upcoming "Raven Ridge" APU. The one Socket AM4 motherboard you buy will work with any AM4 processor! And with support for the latest I/O standards like USB 3.1 Gen 2, NVMe, or PCI Express® 3.0, it’s easy to build a high-performance system that can grow with your needs.
