Explore the angle that's perfect for you with this Professional series monitor, which tilts, swivels, pivots and adjusts for height to achieve the optimal position for extended viewing. Ergonomic design provides handsome style on your desk - or off: this monitor is wall mountable, giving you clear views with more room.
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of Professional series monitor. In-Plane Switching (IPS) technology delivers consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
Convincing
Prepared
Collaborating with others is faster and more productive when you have plenty of ports available. Professional series monitor allows you to connect to a wide variety of useful devices including notebooks, tablets and giant screen TVs, thanks to helpful VGA and DVI connectivity.
Green focus
Professional series monitor is RoHS compliant and mercury free. In addition, you'll see power savings of up to 68% thanks to advanced Acer EcoDisplay technologies and white LED backlighting, which cut your costs and conserve the earth's resources.
Acer V196Lbmd - LED monitor - 19"
LED-backlit LCD monitor - 19"
Panel Type
TN
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
DVI, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
40.64 cm x 20.7 cm x 40.8 cm
3.1 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
