The Acer G series displays engaging high-definition visuals and crystal-clear text on its cinematic widescreen. The brilliant design and simplified functionality make the great value of this monitor easy to see!
The chic black bezel and aviation-inspired base present a polished look that is eye-catching as a desktop PC complement or secondary notebook display.
Brilliant display
The superior resolution, fast response time, and high contrast ratio provide extra-fine details and smooth movement for your favorite entertainment. The 16:9 aspect ratio frames movies and HDTV content perfectly.
Straightforward functionality
Just press the input key on the main menu and the G series automatically searches signals across its VGA, DVI and HDMI ports. A press of the empowering key launches the Acer eColor management onscreen interface for adjusting the setup and color to create a personalized viewing experience.
Acer G227HQL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
49.9 cm 38.4 cm
2.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM)
49.9 cm 38.4 cm - with stand
2.8 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
Stand
1 x VGA cable
MPR II
Power Supply
External
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
490 mW
Dimensions & Weight Details
Without stand - width: 49.9 cm - height: 30.3 cm - weight: 2.5 kg , With stand - width: 49.9 cm - height: 38.4 cm - weight: 2.8 kg
