3M Anti-Glare Filters help reduce glare and mirror-like reflections. Its lightweight, thin, frameless design is easily applied and reapplied numerous times with no bubbles. Designed to fit widescreen desktop LCD monitors with a diagonally measured 21 9/16" viewing screen and a 16:9 aspect ratio. Actual filter dimensions are 18 3/4" wide x 10 9/16" high (477 mm x 268 mm). Protects screen against scratches. Attaches with optically clear adhesive strips that can easily be applied and reapplied numerous times. Easy to clean; includes cleaning cloth. Compatible with most touchscreen displays.
