The CubePro features build platform with ultra high-resolution. With ultra high-resolution settings of 70-micron thin print layers, professional quality printing has never been so large or easy.
CubePro will support nylon, along with strong ABS and compostable PLA plastic for production. Create functional prototype models or make end-use parts for your engineering applications. The CubePro is a versatile printer for both the engineer and hobbyist alike. Nylon is exceptionally durable for high heat resistance, high strength to weight ratio, or parts requiring secondary operations like painting, machining or adhesive bonding.
A controlled process environment ensures improved accuracy and reliability of print for effortless, professional quality every time for your largest ABS plastic prints. Automated settings ensure home-safe printing in your mancave, on your workbench and at your desktop.
